Would it be possible to alert based on a percentage change? For example, if an interface changes bandwidth by 50% then alert me?
Solarwinds confirmed it was not possible. I don't know why the above was marked as a verified answer, the answer is its not possible.
Yes it's possible on the Advanced Alert manager
You can set your alert to be trigger on the following example condition
xmit percent utilization is greater than or equal to 50%
or
Recv percent utilization is greater than or equal to 50%
I believe in that example it would just show me if utilization is over or equal to 50% not a % change. For example, if the percentage change occurred was 60% within a 5 min period (e.g. traffic was at 100% and dropped to 40%) .
Hi dricha07,
I am looking for exactly the same thing. Would you share the solution if you have found it ?
dricha07--
Apologies for the mix up--I've un-verified the other answer and verified yours.
Thx for your feedback.
M
