I haven't seen one on here yet. Can we expect to see one soon? Thanks.
Hi sneak
Have you tried the 'Cisco.Wireless.Lan' device type in CatTools? If so, then at what point did this device type fail with your 5508?
Regards,
Steve
Yes I did try and it eventually fails with this error: Did not receive expected response to command: show running-config. Looking into the debug, I see that it does start to get some return from show run-config, but seems to quit at this point:
--More or (q)uit current module or <ctrl-z> to abort.
When you telnet or SSH to the device and issuing a show run-config, you have to hit enter button to have it display the entire running-config. Seems this is where the script is hanging.
Hello,
I am setting up the same scenario with a WLC5508. Was there any resolution to this thread?
thanks,
james
Hi James,
Take a look at the following thread:
Hope this helps.
All--
Marked for PM as well. Thanks for the feedback.
M
