I'm trying to create a map in NPM Map Maker. I don't have all the default "Background" maps that I see in the Demo on the Solar Winds site.
It's tucked in there, have another look. Here's a screenshot.
Hi louieb25,
You can download those backgrounds from your customer portal:
http://support.solarwinds.com
Click on Download and Upgrades > Additional Components > Orion NPM > Orion MapMaker
Desc of the download add-on: Provides a number of map backgrounds for use with Orion MapMaker
Yann
Note that you can use any image as a background in MapMaker. Some people use a building floorplan, a Visio or LANsurveyor network diagram, or a screenshot of a Google Map.
I'm trying to find this section to download additional maps, but I'm not having any luck finding it. Is there a new location for those maps?
Bill
My problem is I can't find out how to get to that particular page. I'm really think I'm going blind.
Never mind... I found it... thanks for the help!
-Bill
