Hello,
I would like to either add a column of information to the "Top 10 Subnets by % IP Address Used" display, or add the colored icons such as "% used" from the display to a report.
What column would you like to add? One thing you can do is if you edit the resource, there is a SQL filter capability in there, so you can filter that view based on some property like customer or building etc.
I would like to either add a subnet's comment (with a different column title) field to the Top 10 Subnets by % IP Address Used table. Or add the % IP SPACE USED column to a customer report (with the colored bar).
As bshopp mentioned, you can filter the subnets in the Top 10 resource with SQL. Adding the '% IP Space Used' to a report is easier; you can create a report in Report Writer with this field added to the report.
HTH,
Craig
Guess I am not clear on what I am asking how to do. I want the circled red stuff on the from the first screen cap to show up in the report in on the second screen cap.
Thanks for the clarification. With Report Writer, you've got everything but the bar graphic in the '% IP SPACE USED' column; however, as your screenshot shows, we can still display the actual percentage. Is this what you're asking about... the bar graphic in your first screenshot?
-Craig
