We have CCleaner in our environment, and we are spread out. Does anyone have an suggestions how we can use PatchManager to upgrade CCleaner on our network?
Regards,
Charles Burch
create a custom package and deploy it
Deploying Custom Packages with Patch Manager
How about uninstalling CCleaner if it not .msi file would this be possible with PatchManager?
Uninstalling is possible with exe
I uninstalled all copies here silently using PDQ Deploy and this command line "C:\Program Files\CCleaner\uninst.exe" /S
do you know it it possible to uninstall with PatchMan if the product ID is missing, or do we need to get LanSweeper?
when you say PDQ Deploy is this LanSweeper?
Nope, its PDQ Deploy.
https://www.pdq.com/pdq-deploy/
Its really great software. I use PDQ deploy and PDQ inventory and pay for both but the free version does a lot
