I'm trying to setup disk I/O monitor in NPM. I was looking at this:
How do I setup a UNDP, I've never done that before? thanks.
To just use that UDP you would just download it and save it on your Orion server. Then open UDP, Start -> Programs -> SolarWinds Orion -> UDP. From there you would just import the poller, File - > Import poller. After you import or create a poller it is important that you do the following:
A. Assign the poller to the servers/nodes you want
B. Set the Web Display type and page it is to display on.
Both of these steps can be accomplished by right clicking the UDP in question and choosing the appropriate option. There are a lot of good UDP's already in the content exchange, but it is also easy to configure your own through UDP to get what you are after.
I don't see UDP under solarwinds/orion or in other places. Where else could it be?
C:\Program Files\SolarWinds\Orion\NPM\UniversalDevicePoller.exe.config
I found it under network performance monitor
Okay, and I had posted wrong link.
how high is too high for disk I/O?
