I've tried to add new group to NPM but button is missing... strange... Admin guide told to go in "manage groups" but there is no such a button.
Hello Ismo,
Which browser are you using? Do you have any kind of advertisement blocking plug-in enabled? Button wasn't removed but it has HTML class property named "addContainer" and some extensive blocking filters faulty detects it as advertisement.
Tom P.
Do you have admin access to NPM? It sounds like the "manage groups" restriction is applied to your account
Tony Johnson
Loop1 Systems
http://www.loop1systems.com
Yes, I have admin rights. btw, I didn't find any kind of "manage groups"-restriction from account settings. So I don't even know where it should be enabled...
Would be nice if adminitration manuals had more pictures and screenshots in pages, not just pale text. Now manuals are quite "insipid", and sometimes it's hard to find what you're lookinf for. Like in this case; I can't even know what Orion screen should look like, if there had this "create group" button.
I made an exception for Chrome adblocker, and now I'm seeing this button. Thanks!
same issue ... same fix! Thanks for posting.
