I just wondering if any of you have written a script in powershell that would allow me to monitor if the store is mounted. Occasionally after reboots the store has not been mounted which causes some embarrassment for those that miss it.
Before I spend some time bashing something together, what version of SAM are you using? The latest version has AppInsight for Exchange, and store monitoring is part of the many features available. Otherwise I can probably throw something together over the weekend.
As you're on SAM 6.1.1, it should be possible to add the Exchange monitors to the node with the correct permissions assigned. The documentation for AppInsight for Exchange can be found here. Let me know if that works out for you, if not, I'll throw something together.
Will this work for exchange 2007?
Unfortunately AppInsight for Exchange works on 2010 and 2013, not 2007. Have you looked through Thwack to see if there are templates that already monitor it? I unfortunately don't have an Exchange 2007 environment I could test against, so what I come up with might not work.
