question folks, anyone have a write up on connecting to the Eminentware DB? our SCOM engineer is indicating that the DB is alerting OUT OF SPACE...so our DBAs went proactive on me and tried to increase the DB Size and received a exceed your licensed limit of 4096 MB per DB...Bueller?!
SQL Server 2005 Express Edition has a maximum database size of 4GB.
If the database is not corrupted as a result of being out-of-space, the options are:
so the new extension pack now is supported on remote SQL servers? that's good...do you have a link to the upgrade...i only see the demo...or do you want me to open a case and have support send me the info?
If you opt to choose the first option, here are instructions for upgrade from SQL 2005 Express to SQL 2008R2 Express:
After the install, you’ll need to run a couple of installs to restore some EminentWare prerequisite files that were overwritten:
After those are installed, you can restart the EminentWare Data Grid Service and launch the EminentWare console.
The newest update (1.71.201.0 at the time of this writing) is available on our Product Downloads page. To apply it you'd want to close any open Consoles, apply the Update Only patch to your EminentWare PAS (Primary Application Server), then to any additional server Roles you may have running, then to any remote Consoles you may have.
you rock Kelly...thanks
