Is it possible to schedule a process in solarwinds to export all the IPAM subnet excel sheets on weekly/monthly basis.
not directly in the IPAM itself. but you can certainly use our API/SDK and schedule the Windows Schedueld task to do that. Here is a post I wrote about using IPAM API and how to get FreeIP address, it could be modified to export all IP addresses and subnets into spreadsheet: How to use the IPAM API and get "Free IP Address"
I would like this feature as well.
Plus, I would like it to export everything that import can import. That way we can update many settings much more easily than with the Web page.
=foon=
hi foonly,
can you quickly summarize operations which are painful to do via web (you referring to update operations - I assume "bulk" ones). thanks for sharing.
Currently, export does not export all the same fields as import. It should.
It also does not export everything that is displayed.
Note that, since there are 2 kinds of Import and Display, there should probably 2 kinds of Export (lists of addresses and lists of subnets).
I would be happiest if export would export everything that import imports, plus all other displayed fields. This would allow easier auditing against other databases used by many customers, such as asset tracking, helpdesk, security appliances, etc. In general, we need more consistent naming - or maybe a guide for mapping field names - for display, export, and import. As you can see below, it's hard sometimes to figure out what corresponds with what.
Finally, there should be a choice between exporting in individual subnet files, and all 1 file.
Export
Import
Displayed
Address
Address (IPv6)
Alias
CIDR
Comments
Contact
System Contact
Custom_1
Description
DHCP Client Name
DHCP Reservation
Display Name
DNS Records
Dual Stack IPv6 Address
Hostname
IP Address
Last Boot Time
Last Response
Last Synchronization
Lease Expiration
Lease Remaining
MAC Address
MAC
Machine Type
Subnet Mask
Mask
Response Time
Scope Name
Skip Scan
Status
Subnet Address
Subnet CIDR
System Description
Subnet Display Name
System Location
System Name
System Object ID
Type
URLField
Vendor
=Seymour=
I agree. This is a frustrating task when you want to export multiple subnets from one SW server IPAM and import it to another. I find myself having to go through each subnet and add in things like Subnet Address/CIDR, Group Description, VLAN and Location to the CSVs before importing them.
