Thanks qle-
That's what I was afraid of- can anyone confirm?
Hi.
You don't need to go that far. Grant the user "Allow Node Management Rights". The problem with this is that even if he got the rights there is no way to get to the APM menu.
To fix this use Customize Menu Bars and add http://<orionserver>/Orion/Nodes/Default.aspx to the users menu bar.
Now your user have the needed rights, but is not admin for your entire setup.
Correct. I have a user who wants to create new templates, edit existing settings, etc. in APM.
Admin settings will work for now - I trust him (for now).
