I am seeing periodic blank messages in my Events log, has anyone seen this before and any idea how to fix it?
I'd be happy to paste a screenshot if someone can give me a brief how to on posting an image here.
Thanks!
Steve
Reply-> Options tab- Upload file for screenshot
Thank you sir. I think I've attached the screen shot
What version is this>? What happens on the website when you drill down into that node for details?
Orion Network Performance Monitor 8.5.1 SP3
I can't drill down into it, there's no link on the x'd out event, so I'm not sure where it's coming from.
since all you have to work with is the time/date try this
Run the Diagnostics Utility which can be found in C:\Program Files\Solarwinds\Orion\SolarwindsDiagnostics.exe
