Hi PBlatz
I noticed a post back in 2005 on the thwack site.
You mentioned you entered a time offset in a custom field to fix your report issue to show the local time offet of GMT.
Would you share your report query with me how you got the offset column and time to change on the report?
Ken
Has anyone gotten anywhere with this? I would like to generate reports in local time but since DST is now different everywhere this seems to be more of a problem now and I am not sure if just having the GMT offsets will work without having to update them for DST in each time zone.
This would be an excellent feature and I currently suffer from devices and staff all over the globe and have constant issues with incorrect time calculation about responding and reporting.
I'd like to throw my hat into the ring here and say that would be very helpful for us as well. We monitor our European sites from North America and they currently see everything in Eastern Standard time.
Is Denny or anyone from Solarwinds prepared to comment on this? Its been a question hanging around for years.
I can tell you that it's on the roadmap, and we've been making backend changes across releases to make it possible.
I'll toss in a "Yeah, me too". I'm currently supporting devices in 4 timezones, and that's likely to increase. As an incredibly obnoxious workaround, I have the server running in GMT and I do calculations based on GMT offset for every issue.
Peter
