hi,
Just looking for information on the different systems that people are using to send sms alerts out of orion, i have looked in to NotePager Pro but wonder if people were using anything else ?
Stuart
@hansons
If you log into your network monitors, then click Settings in the upper right
Then click Configure Default Send E-Mail Action
All you need to do then is enter the phone numbers you want to SMS followed by the carrier codes (@vtext.com or @txt.att.net)
We also send the alerts to our Web Help Desk (WHD) E-Mail address which (through rules) assigns a tech, level, and priority.
Finally, just apply the Configure Default Send E-Mail Action as a trigger and you're done!
We do it directly through the web interface on the network monitors. When we setup the alerts, there is a tab for Trigger Actions where we send text messages.
I'll be glad to show you how we do it if you would like.
I have seen the action on the alert but would be intrested if you could share some info on how you have it setup ?
Thanks for the information its a great help i just need to find out now if the vtext service is porvided by O2 uk
Coincidentally, I just went through this process this morning. If I would have been up to date on my Thwack reading, would have saved me some research.
@ mprobus
I found that there was quite alot of conflicting info out there so having the information from above really points you in the right direction and in this case removing the need for an additional app
Hello Hansons,
Check this..
https://thwack.solarwinds.com/docs/DOC-189337
is it available in NPM 11.5.3
i think it is as the feature has been around a while it was more the configuration that i had issues with
