Below are the images reflecting regarding the subject I'm trying to ask. Is there any thing I could do about it? Thanks.
My email: theprophesy16@yahoo.com
Hoping for any help from you guys.
Is the device accessible via SNMP?
Yes it's via SNMP
Does it pass the SNMP test?
I'll check on it. is there some other ways to check other than this?
You could try and connect via snmp manually.
The device needs to be able to be accessed by Solarwinds via SNMP otherwise Solarwinds can not report on it.
