Seems clear from the screenshot that some alerts were triggered while the node was unmanaged.
Don't remember it happening before. Is this normal?
Hello,
It is normal, you will see the alert but all actions will not be executed (sending emails etc..).
Lada
I don't think this is normal Lada - no alerts of any kinds should be executed on unmanaged nodes - and I did get email alerts, too.
Please check settings -> Polling settings -> Polling settings -> Allow alert actions for unmanaged objects -> Should be unchecked.
If options is unchecked, please create support ticket.
thanks a lot
Unchecked, and always has been unchecked.
All in due time.
Just curious if you were able to resolve this issue? I'm am running into the same thing.
