Net Stop DWMRCSDWRCS.EXE -remove
Failed to delete DWRCSh32.DLL and DWRCShell.DLL. Please advise.
KB: How To Manually Install or Remove the Mini Remote or NT Utilities Client Agent Services
I'm checking with our engineering for ideas what could be wrong.
Can you please share more details on operating system version, dameware version?
File Name: DWRCS.exeFile version: 5.5.0.6Description: DWRCSCopyright: Copyright 1991-2006 DameWare Development LLC
File Name: DWRCST.exe
File version: 5.5.0.0
Description: DWRCST Tray Icon
File Name: DWRCSh32.DLL
File version: 6.7.0.8
Description: Shell interface for DameWare Mini Remote Control Application
File Name: DWRCShell.DLL
File version: 6.6.0.2
Thanks for the reply Peter.
I'm checking with engineering. thanks for details!
Any progress/ update? Thanks in advance.
This is quite old version. I would definitely recommend to upgrade to last version.
DLL’s have another version than executable files. After installation in our environment were versions of dll’s same as versions of executables. So issue can be caused by this. I think that as a workaround you could delete them manually from explorer or try to reinstall.
