Is there any way to get local time of alerts where triggereddatetime stored in UTC time zone . Am using swis query to get data, how to get it in local time zone.
Am using python . Pls suggest
If you'd like to convert the timestamp in the results in SWQL, you can use the ToLocal function:
results1=swis.query("select ac.Name,ac.AlertMessage,ao.RelatedNodeCaption,case when ac.Severity=2 then 'Critical' else 'major' end as Severity,ToLocal(aa.TriggeredDateTime) as Alertime from Orion.AlertActive aa left outer join Orion.alertObjects as ao on aa.AlertObjectID=ao.AlertObjectID left outer join Orion.AlertConfigurations as ac on ac.AlertID=ao.AlertID where ac.Severity=2 and aa.TriggeredDateTime>='2019-02-01 00:00:00' order by aa.TriggeredDateTime desc")
Python has libraries that convert UTC to local time.
Thanks for response. below is the query
results1=swis.query("select ac.Name,ac.AlertMessage,ao.RelatedNodeCaption,case when ac.Severity=2 then 'Critical' else 'major' end as Severity,aa.TriggeredDateTime as Alertime from Orion.AlertActive aa left outer join Orion.alertObjects as ao on aa.AlertObjectID=ao.AlertObjectID left outer join Orion.AlertConfigurations as ac on ac.AlertID=ao.AlertID where ac.Severity=2 and aa.TriggeredDateTime>='2019-02-01 00:00:00' order by aa.TriggeredDateTime desc")
TriggeredDateTime is in UTC time zone. How can i use python method to get ti converted, or is there any way to covert using SWQL functions itself.
SWQL Functions · solarwinds/OrionSDK Wiki · GitHub Please suggest.
Thank you
Hi Dan,
Can you advise how to do the same if we need to convert the timestamp in SQL
Depending on the version of SQL Server, you may be able to use AT TIME ZONE to do this conversion:
AT TIME ZONE (Transact-SQL) - SQL Server | Microsoft Docs
There are several techniques that work for older versions, too:
sql - Convert Datetime column from UTC to local time in select statement - Stack Overflow
I tried using this on a report I send out daily for muted alerts on servers but I'm getting an issue now with the report.
SELECT
n.caption as [Device],
n.IP_Address as [IP],
ToLocal(Alerts.SuppressFrom) as [Mute from],
ToLocal(Alerts.SuppressUntil) as [Mute Until]
FROM Orion.AlertSuppression AlertS
JOIN Orion.nodes n ON n.uri = AlertS.EntityURI
