we upgraded to NPM 10.1.3 yesturday and now I no longer see, and therefore manage allo nodes.
I've tried with the ajax and standard versions to no avail
Has anyone else come across this
thanks
Have not heard or seen this report from anyone else. You may want to try re-running the configuration wizard and select the website. If that does not work, then please open a support ticket.
Hello Bshopp,
Did you hear from any other customers? I have scheduled to upgrade to v10.1.3 this afternoon. If there are issues i will reschedule.
Thanks.
Hi Wookey,
what was the solution to this?
Hi Wookey--
Please post back with a case number and answers you got from Support.
M
not heard anything yet. Issues still outstanding all requests for info and details sent back. Ill post something as soon as I hear anything useful.
Hi wookey.
Has there been any resolution to your issue with this patch? I've scheduled patching to 10.1.3 this Friday and am a bit concerned with how slowly Solar Winds has responded to your issue with the patch.
Thanks!
Has anyone had a successful resolution to this problem yet?
Kevin
