Where is the support we paid for?
Why has this issue not been solved or communicated?
Does Soalrwinds care about it’s customers?
Do they realize IT operations must continue despite "Holidays"?
The lights are on but nobody’s home
My suggestion would be to try contacting support directly. 866.530.8040 and asking for an update to the case. Or maybe try posting this issue here for possible resolution?
Been there done that.
How many times does it take?
Is 3 times enough?
I know this doesn't help your case but we have tested on 64bit without issues. This looks to be an environmental issue. I didn' see diags for this ticket. Can you send your diags to support? This will help understand the issue you are seeing.
So the fact that NPM, VOIP, and APM installed just fine, I'm sure it must be "my" enviroment.
New day, same lack of support from SolarWinds.
I understand your frustration when things don't run correctly. I'll talk to support and have them contact you. I believe with additional data from your installation we can help you get up and running. It will at least help us to understand what is happening there as it is not reproducable here at this point.
Andy
