cisco 5509 ~ download config fails
NCM v5.1.1
cannot validate Login Information
Get "Login failed: bad password".
The user level seems to work, but enable fails.
this is tacacs password, so same password for both
I can login manually, and do enable
You can edit the device templates, but you'd need to set the prompt to the device name (e.g. 5509). This means you'd have to have a device template per device if the prompts are just the device name. NCM needs some way to detect that the login succeeded.
If changing the prompts is possible, that seems like the easier route.
Can you post the session trace?
See this post for how to do this:
if I post the trace data here, will it get indexed by google? I noticed that my switch login and password is in the trace data.
Yes. I would blank those out.
this is slightly edited / cleaned version.
[7/23/2009 1:14:26 PM] Device Template: Cisco Catalyst CatOS-1.3.6.1.4.1.9.5.ConfigMgmt-Commands[7/23/2009 1:14:26 PM] System Name: 5509[7/23/2009 1:14:26 PM] System Description: Cisco Systems WS-C5509Cisco Catalyst Operating System Software, Version 5.5(21)Copyright (c) 1995-2005 by Cisco Systems[7/23/2009 1:14:26 PM] System OID: 1.3.6.1.4.1.9.5.36[7/23/2009 1:14:26 PM] OS Image: [7/23/2009 1:14:26 PM] OS Version: 5.5(21)[7/23/2009 1:14:26 PM] Menu-Based mode=False[7/23/2009 1:14:26 PM] -->StateChange: Connecting to server<--[7/23/2009 1:14:26 PM] -->StateChange: Connected to server - idle<--[7/23/2009 1:14:26 PM] Solarwinds.Net SWTelnet9 Version 9.0.27[7/23/2009 1:14:26 PM] Connected![7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> Cisco Systems Console[7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> C[7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] --> [7/23/2009 1:14:26 PM] ProcessLogin State: 0[7/23/2009 1:14:27 PM] --->U[7/23/2009 1:14:27 PM] ProcessLogin State: 0[7/23/2009 1:14:27 PM] --->sername: [7/23/2009 1:14:27 PM] ProcessLogin State: 0[7/23/2009 1:14:27 PM] UserName Prompt detected: Username: [7/23/2009 1:14:27 PM] Send user name[7/23/2009 1:14:27 PM] <-- myuser[7/23/2009 1:14:27 PM] --->m[7/23/2009 1:14:27 PM] ProcessLogin State: 2[7/23/2009 1:14:28 PM] --> yuser[7/23/2009 1:14:28 PM] --> [7/23/2009 1:14:28 PM] --> [7/23/2009 1:14:28 PM] ProcessLogin State: 2[7/23/2009 1:14:28 PM] --->P[7/23/2009 1:14:28 PM] ProcessLogin State: 2[7/23/2009 1:14:28 PM] --->assword: [7/23/2009 1:14:28 PM] ProcessLogin State: 2[7/23/2009 1:14:28 PM] Standard password prompt detected[7/23/2009 1:14:28 PM] <-- mypass[7/23/2009 1:14:28 PM] --> [7/23/2009 1:14:28 PM] --> [7/23/2009 1:14:28 PM] ProcessLogin State: 3[7/23/2009 1:14:28 PM] TimerTick: mstrData=<> State=3 - Connected to server - idle[7/23/2009 1:14:28 PM] Pending Disconnect = False[7/23/2009 1:14:28 PM] --> [7/23/2009 1:14:28 PM] --> [7/23/2009 1:14:28 PM] ProcessLogin State: 3[7/23/2009 1:14:29 PM] --->5[7/23/2009 1:14:29 PM] ProcessLogin State: 3[7/23/2009 1:14:29 PM] --->509 [7/23/2009 1:14:29 PM] ProcessLogin State: 3[7/23/2009 1:14:30 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:30 PM] Pending Disconnect = False[7/23/2009 1:14:32 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:32 PM] Pending Disconnect = False[7/23/2009 1:14:34 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:34 PM] Pending Disconnect = False[7/23/2009 1:14:34 PM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[7/23/2009 1:14:36 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:36 PM] Pending Disconnect = False[7/23/2009 1:14:36 PM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[7/23/2009 1:14:38 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:38 PM] Pending Disconnect = False[7/23/2009 1:14:38 PM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[7/23/2009 1:14:40 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:40 PM] Pending Disconnect = False[7/23/2009 1:14:40 PM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[7/23/2009 1:14:42 PM] TimerTick: mstrData=<5509 > State=3 - Connected to server - idle[7/23/2009 1:14:42 PM] Pending Disconnect = False[7/23/2009 1:14:42 PM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[7/23/2009 1:14:42 PM] TimerTick: Login Timeout[7/23/2009 1:14:42 PM] Disconnected - From: 1.2.3.4
Is your prompt custom? It appears based on the session trace that the userid and password are sent and NCM is waiting for a prompt. All it sees is 5509 without a ">" or ":" so it continues to wait for a prompt.
