We are having problems pulling CPU and memory utilization on our 3 call managers. I have snmp enabled and configured on each of them however the CPU graphs show no utilization and the memory statistics pull no data at all?
Did you ever get this working?
Negative, still unable to pull CPU utilization, are you having the same problem?
Have you tried using a MIB walk utility and polling for that certain OID? I have noticed that Call Managers do not have the cpu utilization polled properly.
Try polling with this OID: This is what is being used for Unix/Linux for the OID's.
CPU: 1.3.6.1.2.1.25.3.3.1.2 in %Memory: 1.3.6.1.2.1.25.2.2 in %
1.3.6.1.2.1.25.5.1.1.2 Add all Values
yes same issue here. I have a number of cucm boxes and none are showing cpu or mem?
Dont really want to use UDPs either until Solarwinds allow us to control the polling frequency of a UDP. example - constantly polling every 120secs for a serial number is daft, multiply this by hundreds and you can see where this is going.
- Is a cisco device
- And supports the Host Resource MIB that has CPU and Memory, which NPM can work with.
