I am running Orion 9.5 SP4 and am experiencing this same problem. I have a case where this is a 68% difference between the two.
Could somebody please explain the difference between how these two different values are calculated so I can better understand why there is such a big discrepancy in some cases?
Thanks in advance for any pointers on this!
I assume you are seeing this on Windows boxes, correct?
Yup, that would be accurate!
Have you looked at some of the articles in the knowledge base on SW.com? There are a couple items in there that may explain the issue you are seeing.
While I was admittedly unaware of the Knowledge Base (thanks for pointing that out, I will be sure to consult with it in the future) I was unable to find anything in there that answers my question on the discrepancies on the memory utilization gauge versus the disk volume physical memory metric.
Disk Volume - Physical Memory: this represents what is in the system. If there is 2GB you will see it is reporting acurately.
CPU Load & Memory Utilization: this represents physical and VM together. If there is 2GB P and 1.5GB V you will see this as 3.5GB and the utilization (%) will be lower.
Also, if you are using Lotus Domino, you will see that CPU Load & Memory Utilization pegged at 100%. This is apparently a flaw.
We adjusted our page display to remove the memory utilization gauge and choose to show only the CPU load.
