I have 15 managed WAN that i would like to monitor from one dash, can this be achieved using Orion?
Absolutely! Just make sure all the devices (switches/routers etc) have SNMP enabled on them and are all accessible from a single server.
Thank you.
The only limitation I foresee is the dash, is it possible to have individual dashes for each site?
I would really like to have one HUD for all locations, I currently use WUG, and uses several mappes to do this.
if i uderstand this corectly you could just make a map that has all the sub-maps feed into it and then monitor from the top map and when there is an issue drill into the problem from the higher level maps.
That will also give you the ability to have the sub-maps available for each site to monitor if that is the desire with out them being able to see other sites.
It there any way to have have several maps one page?
just have an icon for the underlying map that will indicate the status of the sub-map.
so your main map will be a bunch of dots or icons that you choose and then link the map for the site to each of the dots/icons.
main map has 3 icons
site 1
site 2
site 3
then you build a sub-map for each of these and link the sub-map to the icon on the main page.
on the sub-maps you would place the router, switch, users for that particular site.
