Hi Team,
Do we have option to fetch alerts which is cleared by passing Alertobject ID's .
kindly help as we want to notify customer through email once device is up.
rkalidh
If you specifically want to work with alerts using the API, then I'd suggest going through the following documentation.
Alerts · solarwinds/OrionSDK Wiki · GitHub
Otherwise, if you just want to send an email when the device comes back up, you should be able to do that via the alert reset condition, within an alert.
Thanks for the reply. I want to send email when device come up. Am using
python orionsdk to send alerts through email. Could you please help me on
how to check reset condition . Thank you
Plese suggest
I'm curious why the alert configuration's "Reset Actions" options aren't working for you?
Am trying to check if the device came back i should send email, where i
already sent for down status to customer. How to check this in orion
tables? Am using python to get alert details. Is orion. Alert configuration
contains any such property?. Pls guide
On Tue, 4 Feb, 2020, 11:11 PM sturdyerde,
You can do it right in Orion itself (web GUI), but if you must do it through the API, review the SDK documentation on GitHub. You'll need to use the "Reset Action" to send the email when a device is back up.
