Hi :
Is there any way to change this initial login´s dashboard ?
I would like insert my logo in this page.
Please help me. - I need change this:
by this:
So if you go to the Admin section of the web console and under Web console setting I believe you can change the header image as well as the text on the login page.
I put this code in web console´s page:
<img src="/images/inilog.jpg">
but I´m geting this output:
Hi valdemirs--
Try changing the code in the Login.aspx file. Here's the path:
Let me know if this helps you.
M
I´m still trying change this header without success.
Need I change anything in mainlayout.css file ?
Hi valdemirs,
The change you are trying to make is not supported at this time. You may change the header image and add text on the login page through 'Web Console Settings' in Admin.
You can make the changes you described (which are not supported and will break on upgrade and every time you run the config wizard) by doing the following:
1. Look at /Orion/images/BG.LoginBox.gif and replace with a similar (but blue) gradient
2. If you want a blue border, change the border color value in #fancyBackground in mainlayout.css
3. Look at Orion/images/login-title.gif and replace with the ultra logo. You may want to try to add a lot of space on the right side of your graphic to get the alignment you want.
The 3 steps above will get you something similar, but without the rounded corners.
The image you have will not work as it is because 1) It's not sliced up the way the Orion site needs it to be and 2) The form fields are included as an image.
If you wish to make more unsupported changes to Orion's images and css files, I recommend firebug as a firefox add on. It allows you to point at an element on the web page and it will tell you which file to modify. Have fun, but make sure to back up your files
