Hi guys,
Is there any work being done to support Exchange 2016 with AppInsight? Will AppInsight support Exchange 2016 or is it impossible to implement?
Monitor Exchange 2016 using SAM - SolarWinds Worldwide, LLC. Help and Support
Exchange 2016 is supported by AppInsight for Exchange in SAM 6.2.4, currently in Release Candidate.
I installed 6.2.4 and tried to install it using the server configuration tool. It complains that Powershell 2.0 is not installed, but the server has PS 4.0. Have there been other reports of the server configuration tool not working?
I also tried it against our Exchange 2013 servers, and the server configuration tool works fine on those systems.
The following KB article I believe is applicable to your situation.
AppInsight for Exchange: PowerShell is not working - SolarWinds Worldwide, LLC. Help and Support
Thanks. I was able to get past the PS 2.0 issue by asking the Exchange admins to install that along with Powershell Web Access components. There are 2 servers where Exchange doesn't show up when I list resources, but they are running Exchange. My guess is that there is some access control issue because I've configured them the same as all of the others. The Power Shell web access URL responds differently on them than the working ones. That is as far as I've gotten on troubleshooting.
The Knowledge base article was a good angle but the problematic servers already had the pre-requisite registry entries.
Are those nodes managed either via WMI or an Agent? If they're managed via SNMP then AppInsight for Exchange won't be available via 'List Resources'. It's also possible that these Exchange servers are not mailbox servers. AppInsight for Exchange works only against servers running the 'Mailbox' role.
