Hello Everybody,
I would like to know, Is Possible generated backup hourly on NCM module? I do not found the option.
Thanks for your help.
I agree with rharland but why would you want to backup your configs every hour?
If you are worried that changes are being made, then just set up real time change detection. That way everytime someone makes a change, the config is automatically backed up.
I back up my configs once a week and use real time change detection.
If I wanted the backups to occur hourly, I would probably just build 24 daily jobs and have each one run on a specific hour of the day. There may well be a more advanced method to accomplish this.
It would be tough to manage and revert, I'm sure, but would officially satisfy your requirement to perform hourly backups.
Ok rharland2012 thanks for your response, I thought that had any other option for to take this information.
regards,
Exactly superfly99 this was my worried. I have configured the real time detection and work well.
thanks for your help.
regards!!
Excellent, can you please mark this question as answered?
Thanks.
