Has anyone come up with a decent way of using NCM for config management of APC SNMP cards? You can use their CLI to upload configs via tftp, but you can't download them that way. If that was possible a custom template would be no trouble at all.
Hi Jeff - thanks! We're tracking this as a feature request - and we're going to be working on a new device template. I've put your note in the ticket so we'll definitely be in touch when we get a little further into it so we can get your input/feedback.
--Christine
Hi Jeff--
Marked for the PM.
Thanks for your feedback.
M
Jeff - making sure I understand what you need here - do you need to download the configs via SNMP? Or are you asking for a custom template to download the configs via tftp? Sorry - confused.
Christine,
We just need a way to download the config files from APC devices. Right now the only way I see posible is via ftp from the apc device. We would be happy to work with SW and/or APC to work towards a solution of APC config managment. I'm working on a custom template, but one major snag I've hit is there is no variable for the escape key, which is much need for APC devices.
Jeff
Thanks. I've started a device template and will be working on it some more the next few weeks. I will email you what I have when I'm done.
Perfect - thank you!
