Hi All,
I need to present multiple switch UDT information in one view, does anyone have any idea how to achieve this?
I know the UDT Port Information component has to be linked into a node details view. Can I use it on a summary page?
Adam acmtix
Is that not just the UDT Summary Page? You could set up a UDT Summary View with a filter for your specific devices.
Hi David,
I'm trying to generate a view that shows me a specific group of switches sorted by geographic location, listing their port details all on one page. I don't want the users to have to browse through each switch via NPM looking for UDT port details and was hoping I could display multiple switches port details on one page.
I would think that the easiest way to build something like this might be to make a copy of the UDT summary page and then apply a view limitation to it to to narrow it down to the nodes you want.
The summary page unfortunately does not show the port details even with a filter applied. To get the port details you have to browse via npm to each switch and look down the page to locate the port details. Its fairly lengthy to have to do this for 100 switches. I'd like to provide it all on one page alphabetically per switch. I'm thinking it probably cannot be done. Feature request time...
Haha, I scoff at your "cannot be done"
If solarwinds has the data in it you can present it for sure, sometimes it takes some digging around but it's always doable.
I'll try to find some time next time I'm in an environment with UDT running to see what I can spin together. What Info do you need in this summary?
-Marc Netterfield
That sounds great mesverrum we need the info presented in the UDT Port Details. If we can drag it out in a report that would excellent too.
The port number, whether the port is active, hostname, IP address, MAC, VLAN.
