When your installing Agent on one of the server what manager name you have to give ... ??? because it is saying invalid when i'm giving the appliance name ???
any idea
Ive installed remote agent installer on to one of the server ... at the end of installation.. it said.. error occured ...in the installation process..but it ain't showed anything..... do i need to restart the server.. or do i need to re install the agent again ??????
windows 2008 server --> i'm installing agent onto this ... do i need to disable firewall or enable remote desktop... before installing agent??????
I've installed agent on server... but its not showing on the node list on the desktop console....... any body.... there ??????? help pleaseee
Hi, there.
Do you have name resolution set up correctly - that is, can the server resolve the hostname for the appliance?
Here are a few KB articles to check out:
SolarWinds Knowledge Base :: Using the SolarWinds LEM Remote Agent Installer
SolarWinds Knowledge Base :: Troubleshooting LEM Agent Connections
I hope these help.
Phil
I have problem when i'm using uninstall remote agent ?? at the end of the uninstallation... it says there are some errors ...when uninstalling the agent ???? any help regarding this...???
