Hello friends;
I have a problem about HTTPS web console. I configured systems according to this article(Enable SSL or https for the Orion Web Console - SolarWinds Worldwide, LLC. Help and Support ) everything is ok but it works only internet explorer. Others(Chrome, Opera) does not open web console. It says;
Try:
Do you have any idea about this? Thank you.
You have a certificate error shown for internet explorer, but the other browsers are refusing to show you a website with a bad certificate.
Can you resolve that first?
Richard
Have you tried from other workstations? Can you post a screen shot of IE and Chrome with the URL?
it is same for other workstations.
Yes, you are right. I have changed certificate and now, there is no problem. Thank you.
How did you change the certificate. Please provide the steps. I am also having the same problem. Thank you.
