I've been tasked to look at implementing STM and was wondering if it's agent-less or if every server will need an agent installed on it. Just thought I'd throw that out there before I start reading manuals.
There's an agent needed, but there is on inherent to the STM server that you can use. The ability for the proxy agent is to take some of the load off the STM server. Also, depending on the storage, you may have to use an SMIS-Provider. But otherwise, no, no agents on the storage side.
Regarding Windows servers, it does require an agent, however you can designate a server as an agent server and have the polling done through it for another server I believe. It becomes a proxy agent at that point.
Thanks, that's what I was thinking from the snip-it of documentation that I've read. We're only going to use it for SAN monitoring so we should be good to tell our SAN team that it doesn't require an agent on their systems. Yes?
If you want an agentless physical server monitoring tool, I would recommend SolarWinds Server and Application Monitor.
Thanks to both of y'all for the info. That's exactly what I needed to know.
Balki1429: Is that from one of the setup docs in STM? If so, I apologize for not reading through it more carefully.
Ha, I guarantee it's covered somewhere in the docs, but I just built that table from information in my head for this reply :-)
No worries - let us know if you have any other questions.
