I´m looking for desperately any way to schedule a report with report Scheduler each minute.
Is there any hack to get this ?
Alert action escalation. Create an alert for your purposes.
Please, can you tell me more about this ?
https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/Trigger_an_Alert_to_repeat_until_acknowledged_or_resolved
Note step 7: Select "Repeat this action every X minutes until the alert is acknowledged".
For your action, set the report via URL.
I need an action to run a Report (SQL Query) and store the output to a file.
I'm not seeing the use case for generating a new file every minute for anything that is polled from orion, especially since the vast majority of polled data is being collected on intervals between 2-15 minutes. Why wouldn't you just set the polling intervals to collect your metrics every minute and then run a report showing each datapoint for an entire period of time?
