I like being able to scroll through the pages on the web interface, though I'd like to export/print to the different options like you can in the full client. Is this on the road map somewhere? Or even a nice print friendly version?
This is on our roadmap. Are you primarily interested in reports (inventory and compliance)? If so, how would you prioritize your options? It's not likely that we'll be able to provide all of them at once.
E.g.
1. Printable version
2. Export to MHTML
3. Export to PDF
Export to PDF/Excel definately for the reports, printing would be low priority as we could print after the export. What brough this up was running the chassis ID report for support contract renewal, I liked scrolling through the 50 pages, but to gain anything other than view, I had to get into the full GUI.
I was directed to this stream as well.
I was asking for XLS type files. I see that as a "must have" for using the report. Seeing it is fine but we have other needs as well.
Thanks for the feedback. In the interim, you can go to NCM client application and run the report and then chose File > Export > Excel spreadsheet
Has this feature been added to NCM V7?If so, I might be enticed to upgrade from V6.1.
I'd like to be able to right click in the web page and select Export to Excel, similar to most other Orion web reports.
