Hi, could someone please let me know if the Engineers Toolset (I am using Ver 10) supports sFlow?
I ask because I am going to a site that has HP Procurve switches and we would like to get sFlow stats from the switches.
The Engineer's Toolset Realtime Netflow Analyzer supports Netflow v1 & Netflow v5 traffic. You can try a free evaluation version of our Orion Netflow Trafix Analyzer. It supports sFlow.
Steve
Thanks Steve
So to get the s-Flow i would need a network connection from our Orion Server (with NTA) as the Engineers Toolkit is just going to give me a 1 hour view of Netflow. (Not sFlow)
Regards
Paul
Paul,
Yes, to view your sFlow data you will need access to your Orion Web Console. The Toolset will only be able to display NetFlow data.
We've added this to our knowledge base here http://knowledgebase.solarwinds.com/kb/questions/2053/.
Hello, anyone could you teach me about support versions of sFlow?
I can't find out support versions's sFlow.
I'd like to see Extreme sFlow.
with my best regards.
sFlow is not supported in Engineer's toolset.
Peter
Hello peter,
Thank you for your help. I refer following FAQ.
http://www.solarwinds.com/engineers-toolset/resources.aspx
Q: Can Engineer’s Toolset monitor NetFlow?
A: Yes, the NetFlow Real-time tool captures and analyzes Cisco NetFlow 5 & 9, JFlow, AppFlow, and sflow
Isn't sFlow supported in engineer's toolset?
If I can see sFlow by engineer's toolset, I'd like to know about sFlow's version.
Sorry again.
best regards.
Team is setting up a lab device to test this out. Please stay tuned.
