What is the best way to monitor bandwidth usage at different locations?
Hi amellott,
Could you tell me the purpose ?
To monitor usage & watch for spikes/high usage.
You can see it on the interface details page. However,do not forget to set the values of bandwidth.
You need to monitor the device with SNMP and add the interfaces you are interested in through the List Resources tab. You will then see the interfaces displayed while looking at the node details. You can click on the interface and see an assortment of graphs and details. Hope this helps.
Where do I set those values?
The bandwidth setting are normally applied to the router interface with the 'bandwidth' statement. NPM will pull that information automatically. Another option is under the interface details there is an edit interface link where you can set a custom bandwidth.
