Has anyone gotten Switch port mapper to work with a juniper ex switch.
I keep getting mib bridge not support.
Is ther a switch port mapper that will work with juniper switches
I have . Are you using the WorkspaceStudio version of the SwitchPortMapper?
--Greg
I've been trying to get switch port mapper to work with Juniper EX 4200 switches and I keep getting "do you have read/write snmp enable?" failures. Are you using snmp v3? If so what are your v3 communitry string settings on the Juniper switch? Thanks..
-Vincent
Hi Vincent - what version of the Switch Port Mapper are you using?
I'm using switch port mapper in version 10 of the Solarwinds Engineers Toolset.
Vincent - Can you tell me what version of 10 (like 10.2 or 10.4)? Also, are you using the Classic version, the Workspace Studio version, or the command line version?
Are you using SNMPv3? Does it work via SNMPv1/2c?
Greg
