We have 4 CPTs and only the 10 Gig interfaces are showing up. We just updated the MIB file and still no change. Any ideas on what is going on?
Thank you,
Bruce Jarrett
Hi Bruce,
can you provide more information about your problem, please? Are those interfaces monitored by NPM and have status different from up or they are not even recognized and added in? Can you see those interfaces on the node when you do list resources?
Pavel
Okay so right now it is taking 5 min to discover resources though the NPM web interface – it goes to 83 then waits then to 97 and finally 105 and once again waits. Then it is only seeing the following interfaces:
List Resources - txdfw1cptcor02
Select resources and statistics to monitor:
Wait....
Please wait while resources are being discovered...
Interfaces discovered: 105
Volumes discovered: 0
Select:
All
None
All Volumes
All Interfaces
All Active Interfaces
No Interface Statistics
Topology: Layer 3
motfcc0
pdcc0
pdcc1
pdcc2
pdcc78
pdcc79
pdcc80
fog_1_36
dwdm-cli_4/1
dwdm-cli_4/2
dwdm-trk_4/4
TenGigabitEthernet4/1
TenGigabitEthernet4/2
TenGigabitEthernet4/3
TenGigabitEthernet4/4
dwdm-cli_5/1
dwdm-cli_5/2
dwdm-trk_5/3
dwdm-trk_5/4
TenGigabitEthernet5/1
TenGigabitEthernet5/2
TenGigabitEthernet5/3 -
TenGigabitEthernet5/4 ·
enet_24/1 - MSISC-A-1
enet_24/2 - MSISC-A-2
enet_24/3 - MSISC-A-3
enet_26/4 - MSISC-B-1
enet_26/5 - MSISC-B-2
enet_26/6 - MSISC-B-3
I am not seeing any of my gigabit interfaces.
From the Node Details:
Node Details
Management
Polling IP Address
Dynamic IP
No
Machine Type
Cisco
DNS
System Name
Description
Cisco CPT600 09.512-012-J1835-SPA Factory Defaults PLATFORM=15454-M6
Location
Contact
972-350-6100 Network Operation Center
SysObjectID
1.3.6.1.4.1.3607.1.20.10.70
Last Boot
Monday, January 14, 2013 2:43 PM
Operating System
IOS Image
Unknown
Hardware
Physical
No of CPUs
0
Telnet
Web Browse
Polling Details
Polling Engine
Polling Method
SNMP
Polling Interval
120 seconds
Next Poll
08:03 AM
Statistics Collection
10 minutes
Enable 64 bit Counters
Yes
Rediscovery Interval
30 minutes
Next Rediscovery
08:30 AM
Last Database Update
Wednesday, June 19, 2013 8:02 AM
Current Percent Utilization of Each Interface
INTERFACE
Now on 1 of the devices at one point for some odd reason it saw the gigabit interfaces but will not see them again during rediscovery
TenGigabitEthernet2/1
TenGigabitEthernet2/2
GigabitEthernet36/2
GigabitEthernet36/3
GigabitEthernet36/5
GigabitEthernet36/6
GigabitEthernet36/9
TenGigabitEthernet36/45
TenGigabitEthernet36/46
Ally | Network Operations | Network Engineer - North America
200 Renaissance Center, MC : 482-B05-D66, Detroit, MI 48265
T + 313.656.5037 | M + 517.899.5367
bruce.jarrett@ally.com<mailto:Cindy.Hermiller@ally.com>
so the problem is that you can discover all the interfaces on the device (105) but they are not imported into NPM. I would suggest you to create a support ticked with attached wireshark from the device during list resources/adding node to NPM. It will speed up investigation.
No the problem is that the gigabit interfaces are not being discovered.
Bruce,
this can be caused by various reasons. There can be timeout on the GIB interfaces during discovery or they might not answer to the OID. It also can be caused by the device itself. As I suggested above, create support ticked with the wireshark, it will speed up the investigation.
thanks,
