Could this be something included in a new ver release :
or have you any suggestions on how it could be setup in 9.5
Thank You.
So you would have to continue using this custom resource in 9.5. However, please see this link here, specifically the last bullet. A user could enter comments into here based on an alert that other users could view and report on
So when you say "So you would have to continue using this custom resource in 9.5"
Do you mean this is transferable and if so how ?
I assume you mean the one posted in the link above? If written for 9.1, it will have to be updated for 9.5 as we converted the website language in 9.5
Yes correct (the one posted in the link above). Where this was an easy mod in prior versions it appears much more difficult in the latest version. What help / advice / conversion can you provide as this seems to be a very popular mod ?
I made an ASP.NET resource (9.5 compatible) by combining this code with the stock Down Nodes resource and posted it here: . See if it works for you.
