I wanna backup config for F5-bigIP device, who can provide the template to me? thanks very much!
as I know Cattools for bigIP is ready now.
See content sharing area:
I have download this template and test on my NCM, but it still failure,
show me the message:
cat bigip.conf not such file or directory
how to slove this problem?
Try either using the 'root' credentials in NCM or editing the template to specify /config/bigip.conf.
Hi SamueIB, Thanks for your replay,
but I don't know how to specify /config path in template file,
can you show me the detail command line? following are my lines in current template.
<!--SolarWinds Network Management Tools--><!--Copyright 2005 SolarWinds.Net All rights reserved--><Configuration-Management Device="F5 Devices" SystemOID="1.3.6.1.4.1.3375"> <Commands> <Command Name="MenuBased" Value="false"/> <Command Name="VirtualPrompt" Value="PDM-E10-1"/> <Command Name="RESET" Value=""/> <Command Name="EnterConfigMode" Value=""/> <Command Name="ExitConfigMode" Value=""/> <Command Name="Startup" Value="bigip_base.conf"/> <Command Name="Running" Value="bigip.conf"/> <Command Name="DownloadConfig" Value="cat ${ConfigType}"/> <Command Name="UploadConfig" Value=""/> <Command Name="EraseConfig" Value=""/> <Command Name="SaveConfig" Value=""/> <Command Name="Version" Value="bigpipe version${CRLF}"/> </Commands></Configuration-Management>
Here is my config template for our F5 BIGIP devices:
<!-- edited with XML Spy v4.4 U (http://www.xmlspy.com) by Brian K Rogers (Solarwinds.Net) --><!--SolarWinds Network Management Tools--><!--Copyright 2005 SolarWinds.Net All rights reserved--><Configuration-Management Device="Generic CLI Devices" SystemOID=" 1.3.6.1.4.1"> <Commands> <Command Name="RESET" Value=""/> <Command Name="Reboot" Value=""/> <Command Name="RebootAt" Value=""/> <Command Name="EnterConfigMode" Value=""/> <Command Name="ExitConfigMode" Value=""/> <Command Name="Startup" Value="list"/> <Command Name="Running" Value="list"/> <Command Name="DownloadConfig" Value="bigpipe ${ConfigType}"/> <Command Name="UploadConfig" Value=""/> <Command Name="DownloadConfigIndirect" Value=""/> <Command Name="UploadConfigIndirect" Value=""/> <Command Name="EraseConfig" Value=""/> <Command Name="SaveConfig" Value="bigpipe save"/> <Command Name="Version" Value="bigpipe version"/> </Commands></Configuration-Management>
Using the 'bigpipe' command prevents having to specify any directories. If for some reason you can't use the 'bigpipe' command, you can change the "Startup" and "Running" values to specify the directory where your configs are kept. Example:
<Command Name="Startup" Value="/var/config"/><Command Name="Running" Value="/var/config"/>
The listed template works great, but I'd like to use NCM to generate a ucs config file and download that config as the running config. So far, no luck. I've even worked with an F5 engineer at my location.
Any suggestions?
Thanks!
What about setting CRON on the F5 to run this script right before NCM goes to download the "running" config.
b config save /config.ucs
Would that work?
I thnik this is another request for out-of-box support for BigIP F5. Orion should support BigIP OoB for NPM and NCM. There are lots of requests for BigIP.
By the way F5 config logic is different from Cisco. It may not possible to backup F5 config with NCM.
