How to send email alert if query running greater than 15 minutes,Session more than 24 hours and job greater than 1 hour??
Those would be three different alerts. Below are two examples.
SQL Query Longer than 15min.
SQL Agent Job Duration
This is more of a Orion Core question, but I'm moving this to the NPM forum since I know many of the Core team watches that forum.
To me it looks like alerting on data polled by SAM (if they do). Core part on that is just the engine part (evaluation if condition is true or false). So SAM space will be better place IMO
Thanks Jan! I've moved this to the SAM forum, per your suggestion!! :-D
Thank you.But i am getting the alert as "Alert ${N=SwisEntity;M=ComponentAlert.ComponentName} is down on ${N=SwisEntity;M=Application.Node.Caption}"
How can I get like 'Server name/Database name and query name'??
You can use the Macro browser to add the appropriate dynamic value(s) related to the item that triggered the alert as part of the Trigger Action.
Hi
I am receiving the email alerts on the next day of the issue raised.
Can you please suggest some solution...
The values are only populated by SQL after the agent job has finished executing and has completed. That may explain the delay. If you're looking for more in-depth real-time query analysis you may want to consider looking at Database Performance Analyzer.
