In yesterday's NTA webcast there was discussion about Smart Traffic configuration in NTA.
Where do I get those steps along with the file name mentioned?
Thanks.
Smart Traffic Optimization: We've found based on several packet captures that 95% of the traffic volume may be represented in a little as 4% of flows. This means if your primary use-case for traffic analysis is to get visibility into the Top talkers, you're storing a lot of unnecessary data in your database (impacting DB size and resource/report loading time). You can enable smart traffic optimization and set it to 95%, which means that only those flows that represent 95% of total traffic volume on your network will be stored.
Here are the steps as described in the webcast:
1. Find file NetFlowService.exe.config by default located at “C:\Program Files\Solarwinds\Orion\NetFlowTrafficAnalysis\” and make backup copy of it
2.Open this file in notepad
3. Find the following line in the file and change options as specified below:<pduLimiter enabled="true" allowance="5" restrictionStep="5" globalRestriction="1" globalMinFlows="0" dataPercentageRestriction="95"/>4. Save this file
5. Restart NTA service
Are the CBQoS stats also affected by this or are those stats coming from SNMP?
Michael.
Nope. Those are coming from SNMP polling.
How does this option work? Does it actually just dump 95% of the flows?
Not exactly. The NTA dev team determined that an average of 5-10% of flows in any environment could encapsulate 95% of total amount of bytes. So, in some cases we are storing only 4% of the flows (and dropping 96%) and others we may be storing more than 4% and dropping less. It really depends on the amount of traffic represented in the flow data, which is why this is perfect for customers who are primarily focused on determining network groundhogs using "top talker" information.
