I need the procedure to update solarwinds Orion NPM 10.1 to 11
Please
Best Regards,
Camel TALLA
Release Notes
and
Upgrading Orion Network Performance Monitor
from the Network Performance Monitor Administration Guide
Upgrade path is mentioned below:
Orion NPM 7.8.5 ⇒ 8.5.1 ⇒ 9.1 ⇒ 9.5.1 ⇒ 10.1.3 ⇒ 10.3 ⇒ 10.7 ⇒ 11 (there is a new beta release)
If you have additional pollers you will have to follow the same (but then it has different bits which needs to be used on additional poller)
And if you have other modules (SAM, NTA etc etc) installed on your environment please refer to the Compatibility Matrix mentioned below
Always check the compatibility matrix before you upgrade (you wont see NPM 11 yet, but then I have pasted posts related to NPM 11 below hence upgrade path mentioned by me holds good ):
http://knowledgebase.solarwinds.com/kb/questions/1888/Compatibility+of+SolarWinds+Orion+Products+for+Installation+and+Upgrade#npm
Upgrade link mentioned below:
http://www.solarwinds.com/documentation/en/flarehelp/npm/default.htm#OrionAGUpgradingOrionNPM.htm?Highlight=upgrade
Links related to NPM 11:
https://thwack.solarwinds.com/message/234418#234418
https://thwack.solarwinds.com/thread/66158
Hope the above content helps
I have 10.7 now, but have same question: How do I quickly and easily upgrade from 10.7 to 11.0?
At the time I write this, my humble opinion is is a firm No...There is no easy or quick method.
PLEASE, correct me, for I hope I am wrong.
Yes, I have downloaded the upgrade guide, all 50-60 pdfs of documentation.
I started looking at the first couple of pdf's and decided I do not have time for this.
I am hoping that Solarwinds would produce a video on how to upgrade to NPM 11.
Bryan Smith
Fort Wayne, Indiana
bsmith2277 wrote:I am hoping that Solarwinds would produce a video on how to upgrade to NPM 11.
bsmith2277 wrote:
Maybe something like this 4 minute video?:
Benefits and Steps of Upgrading to SolarWinds Network Performance Monitor v11.0 - YouTube
Was told I need to upgrade NPM before I can upgrade NCM, but during the upgrade it says I have to upgrade NCM first? Which is it? NCM 7.0.2 NPM 10.6.1 now. upgrading to npm 11.0.1 and ncm 7.3.1
read the compatibility matrix referenced above.
Your NCM version is too old to let you upgrade NPM to 11.0.1
and you can't upgrade NCM to 7.3.1 until you have upgraded to NPM11.0.1
NCM 7.0.2 + NPM 10.6 ⇒ NCM 7.2.2 ⇒ NPM 11.0.1 ⇒ NCM 7.3.1
so, you need to upgrade NCM twice
