Hi Solarwinds Community,
1. Are Avaya/Nortel switches supported for NCM? and how to accomplish these task? Can you provide me with the step-by-step guidelines since Im a first time supporting Solarwinds NCM.
Thanks.
Hi acgarcia--
The NCM Admin Guide should help. Specifically, Chapter 1 and 5.
Hope this helps,DH
Thanks Danielle for the response and I have gone through the Admin Guide(but maybe I missed the part) but Im a bit confused as to how would NCM be able to backup configurations as well as upload any configurations changes created on the console to the devices. Is enabling snmp on the nortel devices enough to do all these? Will NCM be able to detect config changes by just enabling snmp on the devices?
Thanks and more power.
What I mean by the above post is that, do I need to enable my nortel devices to send syslog to my ncm for the ncm to notice config changes made on the switches or snmp is enough for this?
I've marked this for the PM to further address your questions.
Thank you!DH
Thank you for your time DH, I need NCM to monitor any changes on nortel distribution and access switches. We dont use cisco switches in the production area only cisco asa for the firewall.
I hope I get a respond soon. I was hoping enabling snmp on those nortel devices would do the trick.
