I've setup all my Cisco WLC webpages and WCS in workspace studio via simple webgadgets. Periodically I get Internet Explorer Script Errors. Is this an error in Workspace Studio or an error with my desktop?
Example Messages:
nsblue - The Workspace Studio uses IE under the covers for the Simple Web Gadget. You can turn off script error notification in IE by going to Tools - > Options -> Advanced Tab (in IE) and unchecking the option shown below:
HTH,
Greg
The settings were as suggested. Could there be anything else causing this?
nsblue - Make sure you restart all instances of IE (including the Workspace Studio) for any changed settings to take effect.
You might also try placing those sites in in your trusted zone, to see if a security setting could be triggering the alert?
I've added the site to the trusted zone and reloaded all instances of IE including Workspace studio and the script errors are still popping up. Is there any other information that I should get to help troubleshoot this?
Dereck
Dereck - looks like you found a bug. It seems that the IE settings for script error suppression are not carried over to the control.msdn.microsoft.com/.../system.windows.forms.webbrowser.scripterrorssuppressed.aspxI will make sure this is corrected in the next update; Thanks for finding this.--Greg
