Applications status are not being updated while polled multiple times. I polled 15 times in an hour. What can be the reason?
When do testing its successfully completed (you can refer below screenshot).
Have you tried turning on the debug log for this application monitor and checking the log there?Turn on application debugging for SAM - SolarWinds Worldwide, LLC. Help and Support That's normally where I start when a monitor isn't working as expected.
Hi Jealers, thank you for prompt response, I have gone through this article but not getting errors or invalid content. Do you have any other way to troubleshoot it?
Nothing beyond what I can find here:
A SAM template status shows Initial Poll in Progress - SolarWinds Worldwide, LLC. Help and Support I'm not sure if you have an additional poller?Maybe try un-manage and remanaging the poller? Not sure if that would actually help or not. It would probably be worth opening a ticket with support if it is still stuck in the initial poll status when all tests are showing it is working as intended.
I am getting below content.
Hi Jeilers,
As I checked SNMP community testing was being failed on existing poller but when I changed the poller and test the snmp its working good and when I compare both pollers config. there are no difference.
1. Go to C:\Program Files (x86)\SolarWinds\Orion\APM\SolarWinds.APM.BusinessLayer.dll.config and open the config file
