Hi all!!!
Anybody knows how add Node Thresholds on view?
Users without admins rights can't edit nodes, but they needed to see thresholds.
hey,
this should do the job:
create a custom query resource paste the SWQL:
select t.name as Alerting_Thresholds,t.level1value AS Warning,t.level2value AS CricitalFROM Orion.Thresholds t INNER JOIN orion.nodes n ON n.nodeid = t.InstanceId Where t.name IN('Nodes.Stats.CpuLoad','Nodes.Stats.ResponseTime','Nodes.Stats.PercentMemoryUsed','Nodes.Stats.PercentLoss') AND (n.nodeID = ${NodeID})
Extra:
i tried to get a case statement to work to change the names but it wasnt playing ball
if your interested or if any one knows why this doesn't work please hit me up:
select case t.name when 'Nodes.Stats.CpuLoad' then 'CPU' when 'Nodes.Stats.ResponseTime' then 'ResponseTime' when 'Nodes.Stats.PercentMemoryUsed' then 'PercentMemoryUsed'when 'Nodes.Stats.PercentLoss' then 'PercentLoss'END as Alerting_Thresholds,n.nodeid,t.level1value AS Warning,t.level2value AS CricitalFROM Orion.Thresholds t INNER JOIN orion.nodes n ON n.nodeid = t.InstanceId Where t.name IN('Nodes.Stats.CpuLoad','Nodes.Stats.ResponseTime','Nodes.Stats.PercentMemoryUsed','Nodes.Stats.PercentLoss') AND (n.nodeID = ${NodeID})
hope that helps
hey, try this:
Thanks.
But I need this
I think the gauges on the Vital stats tab show the thresholds.
It looks like what i need.
This query works fine in SWQL Studio, but this query doesn't work on NodeDetails page.
Anybody knows how filter by current Node?
In SWQL Studio ${NodeID} shows thresholds for all nodes.
But in web query failed.
the query is going nodeid to ${nodeid} I have it working on th nodes details what type of message are you getting? Or is it just everything?
