Has anyone successfully backed up/archived an F5 ARX configuration using NCM?
Jon
I am happy to report that after working with F5 and SW (Destiny & Francois) that our F5 ARX are now being backed up (running and global config).
Jon0966 - if you need a template for this device, please open a support case and we can help you.
--Christine
Thanks, but let's let support give it a shot and then the person asking the question (me) mark the appropriate answer.
I opened a support case and the response was make a feature request. Since NCM is able to log in and pull the basic config, but not the global F5 ARX config, can NCM not issue a custom copy command configured by me to pull the global config versus having to wait a year to several years for just the possibility a feature request will be available?
Jon--
I'll let PM know about your request.
M
I continue to be unimpressed with Solarwinds support of F5 devices in general. NCM does not adequatly capture a backup of the Big-IP devices and the alternatives provided thus really just fall way short of abeing a reasonble supported option.
This, despite F5 supposedly being a "Synergy Technology Partner", which really leaves me thinking this program really isn't about building solutions that help mutual customers.
Hi Brian_crypto,
Point well taken. I will contact you off line.
