I've been testing a new alert for our global ISDN circuits but it hasn't been working as expected. My goal is to setup an alert and notify me via email when a voice T1 or E1 controller goes down (controller issue, Telco issue or physical cable issue).
Our location consist of the following info:
- Controller Type: E1 or T1
- Node Name: XXX-GW1 or XXX-VG1 (XXX is unique in our network and represents the location ID)
- Location: USA/Asia/Europe/Middle East (each router is configured with a snmp-server location command to indicate where that node is located)
Attached is my setup on the trigger condition. No reset condition, suppression. Trigger action is via email which is the same variables I use on our existing alerts.
When I group the E1 or T1 to and apply the 'any trigger condition, doesn't work. Same with the Node Name and Locations. Looks like I have to set this up multiple times to match all. An alert to match E1, another alert to match T1, another to match GW1, another for VG1 and so on...
Is there an easy way to place all conditions in the one alert or may max of 2 alerts if needed?
I'm not sure if the 'Interface Name - Starts with - T1 0' the correct condition I need. I need the alert to monitor the controllers on our Cisco routers.
controller T1 0/0/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
XXX-GW1#sh controllers t1
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
Description: ISDN
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20080918, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (783 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 28 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
